Jul 2nd, 2025, 3:24am
syntax problem A <= #'B C; (Read 2638 times)
MARCE
Guest
Feb 23rd, 2005, 4:48am
Hallo everybody,
can anyone help me?
I need to know what's the meaning of the following expression
A <= #'B C;
(A,B and C are 3 different clocks)
Marce
  IP Logged
Re: syntax problem A <= #'B C;
Reply #1 - Jun 6th, 2005, 8:43am
This isn't really an AMS question; look in your 1364 Verilog reference.
The "<=" construct is a non-blocking assignment, but usually you see something like
A <= #10 1;
B <= #5 0;
With the non-blocking assignment, B gets the value 0 at time 5, rather than time 15 if a regular assignment had been used.  I've never seen a delay specified as 'B as in your example, rather than as a number.  The LRM allows a number or an identifier, not an expression like 'B.
jbdavid
Reply #2 - Aug 3rd, 2006, 6:21am
if there is a
`define B 12 somewhere.. then
#`B would expand to
#12
B may be a clock but `B is a just a macro that could be ANYTHINg..
jbd
jbdavid
