Apr 29th, 2024, 6:15am
Cadence PLL library (Read 52 times)
gogomi
Cadence PLL library
Feb 24th, 2005, 6:47pm
I am trying to use the "example_phase_domain" of Cadence
PLL library to run some test cases but I found out that it's
not that straight forward as I thought. Does anyone here
have used it successfully? Could you please let me know
your settings? Thank you very much!
gogomi
Eugene
Re: Cadence PLL library
Reply #1 - Mar 7th, 2005, 8:53pm
You should not have to change the numerical settings. As for instrument states, there might be a .artist_states directory next to or in the pllLib. I don't remember and don't have access to the tool right now. Which example and which analysis are you trying to run?
