Jul 2nd, 2025, 9:07pm
Delay with buffers in VHDL (Read 2291 times)
ratep2001
Feb 25th, 2005, 6:06am
I have the following problem: I want to implement large delays (50-100ns) on some signals in my VHDL code and fit them into a CPLD, and for that purpose I use chained buffers. However, I found out that although I use the attributes for preservation of nodes/signals ("syn_keep" for Synplify and "opt" for the optimizer), I cannot preserve more than one single buffer.
For example, in the code below I want to fit 7 buffers between the input and the output signal. However, I don't get 7 chained buffers in my pre-fit equations, but just a single buffer buf7 on my input signal. So I end up with just a few nanoseconds of delay, which is far from sufficient.
Is there any elegant way to create more than one buffer, and preserve it from collapsing? I can use either Synplify - Synplicity or Leonardo Spectrum - Menthor Graphics.
Best regards,
Petar
Example VHDL code
library ieee;
use ieee.std_logic_1164.all;
entity delay_block is
     port
           in_signal: IN STD_LOGIC;
           out_signal: OUT STD_LOGIC
end;
architecture delay_block_arch of delay_block is
signal buf1, buf2, buf3, buf4, buf5, buf6, buf7: STD_LOGIC;
attribute syn_keep: integer;
attribute syn_keep of buf1, buf2, buf3, buf4, buf5, buf6, buf7: signal is 1;
attribute OPT: string;
attribute OPT of buf1, buf2, buf3, buf4, buf5, buf6, buf7: signal is "KEEP";
begin
           buf1 <= in_signal;
           buf2 <= buf1;
           buf3 <= buf2;
           buf4 <= buf3;
           buf5 <= buf4;
           buf6 <= buf5;
           buf7 <= buf6;
           out_signal <= buf7;
end delay_block_arch;
