Jul 2nd, 2025, 9:28pm
The Pwl file is empty. (Read 1197 times)
kamesh419
Mar 02nd, 2005, 8:23am
Dear all,
   I have modified many things compared to my last post. That is the reason i am posting a new thread.
The schematic that iam working on now is
http://www.cyd.liu.se/users/~kamva881/temp/circuit.jpg
I tried to simulate it. It gives me an error saying (This is a part of my output.log file)
Quote:
Simulating `raw/tb_DW01_add_cla_width8' on MYHOSTMACHINE at 4:45:30 PM, Wed Mar 2, 2005.
Notice from spectre during hierarchy flattening.
timeSweep: `stop' has the unusually large value of 100 s.
Error found by spectre during initial setup.
Waveform file
`/home/coworker/kameswar/glitches/SIMULATION/CADENCE/pwlFile5' is
empty.
spectre completes with 1 error, 0 warnings, and 1 notice.
spectre terminated prematurely due to fatal error.
But my pwlFile5 is not empty. a part of my pwlFile5 is as follows.
Quote:
v_B1 B<1> 0 pwl '0*(10n)' '3'
+, '0*(10n)+.3n' '3', '1*(10n)' '3'
+, '1*(10n)+.3n' '0', '2*(10n)' '0'
+, '2*(10n)+.3n' '0', '3*(10n)' '0'
+, '3*(10n)+.3n' '3', '4*(10n)' '3'
+, '4*(10n)+.3n' '0', '5*(10n)' '0'
+, '5*(10n)+.3n' '0', '6*(10n)' '0'
+, '6*(10n)+.3n' '0', '7*(10n)' '0'
+, '7*(10n)+.3n' '0', '8*(10n)' '0' ... ...... ... ..
I do not understand where the problem is. every thing that i do depends on this small test circuit which iam developing now. Plz help me.
Thanks in advance,
kamesh.
Truth lies everywhere and partially even with the error.
Re: The Pwl file is empty.
Reply #1 - Mar 2nd, 2005, 9:41am
What you included in your waveform file is a netlist description of a PWL waveform. What Spectre expects in a waveform file is simple time-value pairs, and they must consist of simple numbers, not expressions. Thus, the file should contain something like the following.
0 3
10e-9 3
10.3e-9 0
20e-9 0
kamesh419
Reply #2 - Mar 2nd, 2005, 10:14am
Thank you ken for the reply.
I know that your suggestion works. by using your method i get the digital wave form and not the analog one i believe. Modelling a digital waveform can also be done by using a simple verilog testbench instead of using vpwlf sources. But the problem is i cannot model the transitions from 1-->0 and from 0-->1, like using raising and falling times.
Can i make use of my netlist description of PWL waveform in any way so that i get the analog description of a wave and not a digital one ? or can i use your method to do this in any different way ?
Thanks in advance,
kamesh.
Reply #3 - Mar 2nd, 2005, 10:14pm
The waveform I showed is a PWL waveform, so it does transition smoothly between specified values. In this case it takes 300ps to transition between levels.
