Dec 15th, 2025, 2:44am
How to do parametric sweep in Spectre language? (Read 2088 times)
James
Guest
Mar 24th, 2005, 2:16am
I want to know the syntax of Parametric Sweep in Spectre language.
I need to add Parametric Sweep commonds in a spectre simulation file, but dont know how.
Does anybody know?. I mean do not use the simulation tool of Analog Design Enviroment, just insert the commonds into the spectre simulation file.
  IP Logged
Re: How to do parametric sweep in Spectre language
Reply #1 - Mar 24th, 2005, 5:32am
spectre -h sweep
will answer your question.
James
Guest
Reply #2 - Mar 24th, 2005, 5:07pm
Thanks, but I need more details.
For Example:
I want to change the voltage of signal Vctr from 0V to 1V with the step 100mV. At each voltage, I need to simulate the ckts 100ns.
How to write the code to achieve the above setting?
Many thanks
  IP Logged
James
snowfiled
Reply #3 - Mar 26th, 2005, 5:11pm
Who know how to write these commonds?
James
Reply #4 - Mar 27th, 2005, 10:17pm
Well, reading the documentation (cdsdoc) would have allowed you to work this out for yourself.
For those unable to research simple things themselves, here's what you'd do:
// your circuit is here somewhere
// this source may already be in your circuit, but this
// is for illustration
vctr1 (Vctr 0) vsource dc=0
ctrsweep sweep dev=vctr1 param=dc start=0 stop=1 step=100m {
  tran1 tran stop=100n
James
snowfiled
Reply #5 - Mar 28th, 2005, 4:53pm
Embarrassed
I'm so shame
James
