stephen
I guess the right way to do is to modify the rule to add a little tolerance. I checked the rule and it seems I have to modify many lines, like resistance tolerance, mos tolerance, capacitor tolerance, etc. Is there any general tolerance which controls all the devices?
[quote author=Andrew Beckett link=1108324028/0#3 date=1108401131]Either way, I wouldn't consider that a tool bug. There are quite likely to be differences in floating point calculations between different hardware platforms. By luck you've not hit this problem before (probably because all the testing was done on another platform), but it is dangerous to rely on exact matching of floating point numbers, IMHO.
I've not seen any reports of similar problems with Assura, so I doubt it's a tool bug.
Andrew. [/quote]
