This means that the Diva rules are inconsistent with the technology file you're using.
The technology file defines a set of layers, and then the Diva rule accesses layers by name. If that named layer doesn't exist in the tech file, then such an error will occur.
You need to use consistent data - make sure that you got the Diva rules and tech file from the same source, and that they are consistent versions.
