lancer
To whom It may concern, I am currently in a digital electronics class and we are just getting exposed to Verilog. To test our knowledge of the language, we were asked to simulate logic gates using FET's. Problem is when I tried to design the basic inverter, there seemed to be logical errors even though the syntax was correct. I am wondering if there was something special about using FET's in verilog that I am unaware of. Right now, all I know is that for nmos, the syntax is "nmos(data, output, ctrl)" and pmos would be the same except with pmos in place of nmos. Using these , I keep getting the undefined output "z" instead of a logic 0 or 1 for all input configurations and I cannot figure out why. If anyone can understand what the hell I am saying, please help me out... I am in a serious JAM here.
If it helps, here is code I have so far
********************************************* module fet_inverter(in, out);
input in; output out;
supply1 vdd; supply0 gnd;
nmos(gnd, out, in); pmos(out, vdd, in);
//Test Module
module test_inverter; reg in; wire out;
initial begin
$monitor("%d %b %b", $time, in, out);
in = 0; #5 in = 1;
#10 $finish;
fet_inverter inst_1 (in, out);
The truth table this produces is as follows:
********************************************* Time In Out 0 0 1 5 1 1 7 1 z ***************************************** This is obviously wrong and I cannot figure out why............ HELP ME
