Aug 15th, 2024, 11:28pm
- How to start up an oscillator in SpectreRF - (Read 561 times)
Alez
Guest
Apr 01st, 2005, 5:23am
Dear all,
I have some problem about simulating an oscillator.
My oscillator has no voltage/current pulses to start up,
it just takes a while before the output signals growth
and stabilized. But, surprisingly, when I applied a
voltage pulse as the supply voltage, the oscillator does
not work !!!!
------------ My problems are: ---------------
- In SpectreRF simulation, how should I start an
oscillator and can be sure that it will work in reallity ?
- I found that, in PSS simulation, SpectreRF does not
allow using any voltage/current pulse in a circuit. So,
how could I start it up ???
Thank you all in advace,
Alez
  IP Logged
Paul
Switzerland
Re: - How to start up an oscillator in SpectreRF -
Reply #1 - Apr 1st, 2005, 6:19am
Alez,
if you search this forum with "oscillator start-up", you find the following post:
http://www.designers-guide.org/Forum/?board=rfdesign;action=display;num=10661882...
I guess it should answer most of your questions.
Paul
Reply #2 - Apr 2nd, 2005, 8:05am
As a further note, you can apply an impulse with a pulse source - just don't specify the period. That way the source is then a one-shot and not periodic. You can't have periodic sources when you're using PSS in autonomous mode.
