Alez
Guest
Dear all,
I have some problem about simulating an oscillator.
My oscillator has no voltage/current pulses to start up,
it just takes a while before the output signals growth
and stabilized. But, surprisingly, when I applied a
voltage pulse as the supply voltage, the oscillator does
not work !!!!
------------ My problems are: ---------------
- In SpectreRF simulation, how should I start an
oscillator and can be sure that it will work in reallity ?
- I found that, in PSS simulation, SpectreRF does not
allow using any voltage/current pulse in a circuit. So,
how could I start it up ???
Thank you all in advace,
Alez
