Alez,
this is not an easy task, as each FR4 supplier has its own manufacturing "receipt". The best way to get acceptable results is to get the parameters from your PCB supplier. The parameters depend on the exact materials used. Also take care on gold plating and so which may modify your line thickness.
You can also have a look at the following message board:
http://www.edaboard.comPaul
