Sep 21st, 2026, 10:01am
Voltage Conversion Gain Mixer (Read 4770 times)
DDC
Nov 27th, 2012, 12:03am
I want to measure the voltage conversion gain of my gilbert cell downconversion mixer (frf = 2.4GHz, flo = 2.34GHz). I think I can only measure the power conversion gain with a spectrum analyzer. Is there an equation to calculate the vcg from s-parameters or an other method to evaluate this ? Thanks for response.
rfidea
Europe
Re: Voltage Conversion Gain Mixer
Reply #1 - Nov 27th, 2012, 11:35am
Use the relationship between voltage and power, P = Vp^2/(2R). So, is your source resistance is RS and the load resistance is RL the voltage gain is
Gv = Vout/Vin = sqrt(Pout*2*RL)/sqrt(Pin*2*RS) = sqrt(Gp)*sqrt(RL/RS)
or in decibel
Gv,dB = 20*log(Gv) = 10*log(Gp)*10log(RL/RS) = Gp,dB*10log(RL/RS)
Usually both your signal source and spectrum analyser is 50 ohm. Is your inputs and outputs designed for handling that?
