Aug 14th, 2024, 11:15am
---- FR4 PCB Substrate parameters ---- (Read 13281 times)
Alez
Guest
Apr 01st, 2005, 5:25am
Dear all,
I am trying to simulate my PCB with FR4 substarte but I
could not find the parameters of this substarte.
Does anyone have this information ?
Best regards,
Alez
  IP Logged
Paul
Switzerland
Re: ---- FR4 PCB Substrate parameters ----
Reply #1 - Apr 1st, 2005, 6:15am
Alez,
this is not an easy task, as each FR4 supplier has its own manufacturing "receipt". The best way to get acceptable results is to get the parameters from your PCB supplier. The parameters depend on the exact materials used. Also take care on gold plating and so which may modify your line thickness.
You can also have a look at the following message board:
http://www.edaboard.com
Paul
Alez
Guest
Reply #2 - Apr 1st, 2005, 8:35am
Thanks a lot Paul Smiley
  IP Logged
larry flowers
toronto
Reply #3 - Sep 18th, 2012, 10:18am
FR4 is not a good choice of PCB substrate for circuits that operates at above 1 GHz.
larry
raja.cedt
Reply #4 - Nov 17th, 2012, 6:39am
Better use Arlon.
raj.
