May 18th, 2024, 11:24am
initial condition setting in oscillator simulation (Read 4021 times)
Alez
Guest
Apr 04th, 2005, 7:26am
I am trying to simulate a VCO and I would like to set
initial condition to start it up.
What should I do in Spectre ?
Thank you for your reply,
Alez
  IP Logged
Re: initial condition setting in oscillator simula
Reply #1 - Apr 4th, 2005, 11:29pm
Try spectre -h ic
Alez
Guest
Reply #2 - Apr 5th, 2005, 6:09am
thanks Andrew,
But I mean, how to set it from the "Analog Design Environment" menu.
I found one way:
Simulation --> Convergence aid --> initial condition
and also Initial condition setting in "Transient" analysis
Confusing about this ???
  IP Logged
Reply #3 - Apr 5th, 2005, 10:45pm
Ah, you didn't mention that you want to know how to do it from ADE. The importance of asking the right question!
The Simulation->Convergence Aid->Initial Condition is a way of creating ic statements in the netlist, having set them up by pointing at nodes on the schematic.
The initial condition options on the transient analysis (readic, skipdc etc) are for if you have a file containing initial conditions. Doing it this way only affects the transient, whereas doing via the sim->conv->ic menu will affect all analyses (because it affects all the DC solutions), unless of course you've set the option in that analysis (ic=none - I
think that's the option off the top of my head).
