Is a recent subversion though? Help->About in the CIW should tell you the subversion and build date (I think), or you can do "icms -W" and "icms -V" from the UNIX prompt to tell you.
I assume you've ticked the oscillator option on the PSS form, and have set the nodes for the oscillator mode to be the output of the divider?
Have you tried setting liberal, moderate, or conservative errpreset, and leaving everything else at default (hit the defaults button on the PSS options and the Simulator->Options->Analog form).
