May 19th, 2024, 8:44pm
PSS predicts a wrong oscillating frequency !!! (Read 3356 times)
Alez
Guest
Apr 06th, 2005, 11:18pm
seems to have many problems from VCO simulation Shocked
I'm simulating a VCO and I found an error from PSS.
From my simulation, in transient analysis, I found that
the VCO oscillates at 2.8 GHz (by measuring the period
of the output waveform). But from PSS, it shows that
the oscillating frequency is 3.5 GHz !!! How come ???
I tried to set many different "tstab" and different time
interval (tstart tstop) in transient simulation, but PSS
always shows 3.5 GHz !!
Could anyone explain me about this problem and how
to solve it,
Thank you all in advance,
Alez Smiley
  IP Logged
Re: PSS predicts a wrong oscillating frequency !!!
Reply #1 - Apr 7th, 2005, 1:31pm
Please don't post the same question in multiple fora - it makes it harder to keep track of.
I responded to this in the RF Design Forum. I suggest anyone else does so there, since it's been started there.
Alez
Guest
Reply #2 - Apr 8th, 2005, 12:17am
Andrew,
not sure what you mentioned. You mean I also posted in this
question in the RF Design forum ....
strange !
I think I only posted it here ??
If I were wrong, meaning I did some mistake Sad
Could you bring me my question in the RF Design forum
Alez
  IP Logged
Reply #3 - Apr 8th, 2005, 6:20am
Hi Alez,
My apologies. A very similar question was posted by someone else, and I assumed it was the same person.
I should try being awake when I post...
One problem might be what I described there:
http://www.designers-guide.org/Forum/?board=rfdesign;action=display;num=11128202...
Another problem might be that when you're looking at the output waveform, I assume you're looking at the initial transient, or a separate transient run. What may happen is that this is not the final, settled, frequency.
Remember that PSS accellerates settling, and so it may be that you need to run a very long transient to see it settling on 3.5GHz.
Andrew
