Aug 23rd, 2024, 10:17pm
unit gain buffer problem (Read 8282 times)
capri
Apr 19th, 2005, 1:01am
                   |---------------s3------+
                   |            |-------s2-- -+
vin------s1---+--||-----+---|\           |
                               x     I +-------+--- vout
                             gnd--|/
In the above typical circuit, when s2 open and s3 close, Vx, the negative node of amp will drop below vss. The problem is if I design the switch2 by a nmos transister, just like the example given by razavi's book, when Vx drop below the threshould voltage of s2 nmos, s2 will turn on again( if I add vss to nmos to cut-off the switch).
That will lead the Vout cannot follow the vin in the end.
If I want to cut the s2 completly I should add a undershoot voltage(-vdd), how can I generate -vdd? or any other ways to turn off the s2 completely?
thanks
Sid
Re: unit gain buffer problem
Reply #1 - Apr 19th, 2005, 9:48pm
Hi Capri,
You SHOULD avoid voltages below GND in your circuit if you are using a normal n-well process with GND as your "lowest power-supply" voltage. So, do not attempt to generate -Vdd.
I will assume your actual implementation is fully differential. The reason your op-amp's input common-mode (CM) voltage is going below GND is because your input signal's CM voltage (i.e. vin's CM value) is greater than the opamp's CM output voltage (vout's CM value).
Assume for discussion the common-mode DC value of vin = 1 V. Assume the common-mode DC value of vount is 0V. Hence in phase 1 when S1 and S2 are ON the voltage across capacitor CH = 0-1 = -1V.
Then when you "flip" the capacitor by turning ON s3, the CM voltage at X will go to -1 V (since the output common-mode level is forced to still be 0V by your common-mode feedback circuit).
Whatever the cause, understand that a "flip-around" amplifier will have a common-mode step at the input if the "op-amp output" and "input-signal" CM levels are not perfectly matched. You should design your opamp to tolerate this.
Sid
capri
Reply #2 - Apr 20th, 2005, 5:22pm
Thank u for your explain, but I still dont know how to modify my opamp design to match the cm input voltage with cm output voltage. The cm input voltage is varied with different input, while the cm output voltage is a fixed value. How can I match them? By adding a 1/2VDD voltage to the positive node of opamp I can avoid the voltage below gnd, but if I have to fix the positive node to gnd, how can I modify my design? Thanks
Sid
Reply #3 - Apr 20th, 2005, 6:24pm
Hi Capri,
I can help you better if you give me more details of your design.
1) What is your OTA architecture (i.e. op amp)? Is the input device NMOS or PMOS?
2) What range of input CM voltages does your OTA work under (i.e. all your input transistors and current sources are in the active range)? You can check this range by varying the input CM voltage and checking the minimum and maximum input CM voltages under which all transistors are still in active region with a DC operating point analysis.
3) What is your OTA's output CM voltage?
4) What are your power supplies?
5) What range of "input signal" CM voltages do you want to tolerate?
Exact numerical values will be helpful.
Sid
capri
Reply #4 - Apr 20th, 2005, 7:53pm
Hi, sid
thank u for your patience
[quote author=Sid  link=1113897719/0#3 date=1114046677]Hi Capri,
It is a two stage opa with rail to rail folded cascoded input stage, both nmos and pmos are used.
so it's from 0 to vdd
almost 0v
vss:0v
vdd:5v
0~5v
Sid [/quote]
Thank you
Sid
Reply #5 - Apr 20th, 2005, 8:40pm
>> So, your input stage consists of a parallel of NMOS >> and PMOS (right?). Is it similar to Fig 9.48 on Pg. 326 >> of Dr. Razavi's textbook?
>> If this is the architecture you are using, then yes,
>> your input common-mode can go from 0 to 5V.
>> Ummmm interesting choice....
>> Remember the gain BW of this OTA is probably a
>> pretty strong function of input common-mode!
>> Okay.
almost 0v
>> Why is your output common-mode not 2.5 V? Why >> did you choose your output CM to be 0V? How can >> you get any output voltage swing if you choose your >> output common-mode to be 0V?
>> Why not make the output common-mode 2.5 V?
vss:0v
vdd:5v
0~5v
>> One important question is, why did you choose the >> flip-around gain-of-1 S/H architecture. Typically, this
>> architecture is used only if you really need LOW-
>> NOISE and HIGH-SPEED. However, it has definite
>> input
>> common-mode voltage restrictions. So, if you can
>> tolerate lower speeds and higher noise, but input
>> common-mode tolerance from 0-5V is important, you >> may want to consider using an architecture like in
>> Figure 12.41 page 432 of Dr. Razavi's book.
Sid
capri
Reply #6 - Apr 20th, 2005, 9:15pm
sorry, I made a mistake, the cm output voltage is 2.5v.
The reason I want to apply this architecture is because I want to design a buffer interfacing the DAC to loads, the output range of DAC is from gnd to vdd. I need a high resolution and high speed buffer to sample the voltage and drive the load. Is there any other architectures can realize it? thank you.
Sid
Reply #7 - Apr 20th, 2005, 9:49pm
What is the resolution of your DAC and what is its speed?
I am not a DAC expert and hence do not know much about your specific design interface. However, assuming your DAC is high-resolution, the design of the unity-gain buffer is non-trivial. Of the top of my head I am not sure if a switched-capacitor buffer is what you need. If your DAC output is continuous time, you may need a continuous time buffer, which is if anything even tougher to design for high-resolutions.
Let me know your DAC's speed and resolution. I will see if I can suggest something.
Sid
Sid
capri
Reply #8 - Apr 21st, 2005, 12:28am
hi sid,
the dac is 10bit and it is not continuous time.
The settling time of buffer should less than 60us.
thx.
Sid
Reply #9 - Apr 21st, 2005, 6:51am
You may want to try using the 2-capacitor unity gain S/H architecture in Figure 12.41 page 432 of Dr. Razavi's book. It is quite insensitive to input signal CM variations. However, if you want to go from 0 V to 5 V you may still have some issues. You need to try it out, I cannot say much more from here.
Best of luck,
Sid
capri
Reply #10 - Apr 21st, 2005, 6:19pm
thank you sid.
