Aug 16th, 2024, 7:23am
Oscillator Phase noise analysis (Read 114 times)
ganesh
Apr 21st, 2005, 4:45pm
Cyclostationary noise processes are accurately characterized by time varying power spectral density.
In some cases just time average power spectral density is sufficient to characterize the cyclostationary noise, while in other cases it is not the case.
My question is for Oscillator phase noise analysis is it sufficient to characterize a colored cyclostationary noise by its time average power spectral density ?
Ganesh.
Frank Wiedmann
Munich, Germany
Re: Oscillator Phase noise analysis
Reply #1 - Apr 22nd, 2005, 5:40am
The noise of a free-running oscillator close to the carrier is almost pure phase noise (see section 3 of http://www.designers-guide.org/Analysis/PLLnoise+jitter.pdf). This means that for low spectral frequencies, the variation over time of the cyclostationary noise in V/sqrt(Hz) will be almost perfectly proportional to the absolute value of the slope of the oscillator signal. With this knowledge, you should be able to reconstruct the time-varying power spectral density of a free-running oscillator at low spectral frequencies from its average power spectral density.
