The command is the same - it's the same simulator.
My (wild) guess is that you're using IC5033 (or earlier). In that version, wavescan only supported ac, tran, dc and sp analyses - and none of the RF analysis.
If you're using IC5141 wavescan standalone supports all these analyses outputs.
So if using IC5033, you'll need to use "awd" to look at the results.
