Jul 20th, 2024, 1:25am
capacitance calculation in spectre (Read 2566 times)
jfyan
Guest
May 01st, 2005, 7:24am
hi all:
in spectre, if i run a .tran  analysis, i can get node capacitances,but there are 3 types(such as node,nodetonode,nodetoground) and fixed value and varying value. so if i want to know the capacitance of a oscillating node during the simulating a ring oscillator, what can i do ?
thanks in advance.
  IP Logged
Re: capacitance calculation in spectre
Reply #1 - Jun 6th, 2005, 9:01am
If the node is oscillating, the capacitance is also oscillating.  You can probably get the capacitance at a collection of timepoints using the reported node capacitance, or figure out the appropriate device capacitances from the connected devices and add them up.
I'm not sure how accurate the reported capacitances are, though: if you have a small resistance between the node of interest and a huge capacitance, does that capacitance show up?  You may want a driving point impedance, computed by capturing the transient operating point and using that as the op pt (skipdc?) and then injecting a current into the node and measuring the imaginary voltage.
