First of all, I assume you're using PSS in autonomous mode (i.e. checking the oscillator checkbox on the PSS form, and pointing at the output of the divider) - or from netlist level, using:
mypss (divideroutp divideroutn) pss ...
If you're doing that, are you using a recent IC5033 or IC5141 subversion? There were some problems a few months back where the oscillator mode stuff was not working that well for a while - although I think wasn't so much convergence difficulties but actually converging on a multiple of the period.
