Jul 16th, 2024, 7:53am
PSS convergence of a VCO with a divider (Read 3071 times)
tromeros
Greece
May 29th, 2005, 1:29am
I have designed a ring oscillator followed by a frequency divider which is described using the Verilog-a language. It is the same divider presented in the paper "Hidden state in SpectreRF". The PSS analysis of the oscillator alone works fine. The PSS analysis of the divider with a sinusoidal input signal works also fine. However when I combine the two blocks together I get convergence error and never achieve a steady state. I have set a stabilization time (tstab) but I don't get succesful results. I wonder what is wrong. Thanks in advance.
Tromeros  :)
Re: PSS convergence of a VCO with a divider
Reply #1 - May 31st, 2005, 10:46am
First of all, I assume you're using PSS in autonomous mode (i.e. checking the oscillator checkbox on the PSS form, and pointing at the output of the divider) - or from netlist level, using:
mypss (divideroutp divideroutn) pss ...
If you're doing that, are you using a recent IC5033 or IC5141 subversion? There were some problems a few months back where the oscillator mode stuff was not working that well for a while - although I think wasn't so much convergence difficulties but actually converging on a multiple of the period.
