Do "save M0.main".
What is happening here (I expect) is that the model is a subckt, and the device is within the subckt. So you need to give the hierarchical path to the device instance when you do the save.
Often these things are done as inline subckts, which removes the need to specify a hierarchical path - however, if the subckt contains other devices in parallel, the reported current when an inline subckt is used is for the inline device, and not the subckt terminal, and so in that case people tend to revert to a conventional subckt for those types of models.
