May 4th, 2024, 4:33pm
bandgap question (Read 8141 times)
RobertZ
the art of analog
San Diego, CA
bandgap question
Jun 21st, 2005, 3:49pm
I designed a bandgap circuit, and ran temperature sweep at different conrers. The output voltages were distributed from 1. 18 (at one corner) to 1.22V (at anther corner).  How to minimize this range to 1.2V +/- 1%, say, 1.188 to 1.212. Any guidelines and suggestions?
I noticed the output voltage was more dependant on the resistor's corner than other factors.
Thanks advance!!!
-driveforce
Robert
ericjohnson
Re: bandgap question
Reply #1 - Jun 21st, 2005, 5:25pm
Did you use an op amp to regulate the biasing? Also, here are some of my thoughts.
Basically the reference voltage can be expressed as:
Vref = Vbe + (R2/R1 ).delta(Vbe). You really couldn't do much about Vbe term except for choosing the appropriate current level. If you have some kind of regulation, then you have better control on the PTAT current. And a good layout will significantly improve the matching for the BJT pairs and the resistor ration. By the way, what kind of resistor did you use?
Just my 2cents.
Eric
RobertZ
the art of analog
San Diego, CA
Reply #2 - Jun 21st, 2005, 7:47pm
Hi, Eric,
I used an opamp.
In the typical corner, the variation is small (less than 1mV). The problem is the difference between differnt corners. Vbe changes a lot corner by corner, but delta (Vbe) doesn't change.
Any other comments?
-driveforce
Robert
Reply #3 - Jun 21st, 2005, 8:54pm
Driveforce,
   Is the current result unreasonable? From your description, you are
using a typical bandgap core, ratioed devices with a resistor in the
series with the emitter of the larger device stacked on top of a
resistor. Is this the structure you are using? In that case, you are
matching a transistor to a resistor.
             Rptat = Vt * ln C / [ Iptat] , where C is the device ratio  8(?)
So you are achieving about +/-2% untrimmed with +/-10 % [or more]
variations in your components. Seems like you are doing pretty good
already. Also from "Voltage References" by Gabriel Rincon-Mora,
page 122, the expected untrimmed accuracy of a PTAT source is
2%-3.5%.
Seems like you need to consider trimming to meet your target.
ericjohnson
Reply #4 - Jun 21st, 2005, 9:41pm
It's nice to hear from you again, Sheldon.
As Driveforce mentioned, the large variation of Vbe causes the Vref variation, but Vbe itself is determined by the process of which the designers don't really have control.
Could you provide more information on how the trimming can be performed? Is this done at wafer-level? How do the manufacturers (such as ADI or TI) perform the measurement and adjustment? Thank you.
Warm regards,
Eric
RobertZ
the art of analog
San Diego, CA
Reply #5 - Jun 21st, 2005, 10:14pm
Sheldon and Eric,
Thanks for your reply.
The current is reasonable (with +/- 20%) at different corners, and all the transistors are in saturation.
The structure is almost like what you said, but with 2 additional resistors are connected at the input of the opamp respectively.
by the way, what is trimming?
-driveforce
Robert
ericjohnson
Reply #6 - Jun 21st, 2005, 10:49pm
Trimming is a way to add or reduce resistance after fabrication. Usually this is done with laser. I think this technology has existed since the 60's...
RobertZ
the art of analog
San Diego, CA
Reply #7 - Jun 22nd, 2005, 9:14am
Eric,
Will this be done for each commercial chip? won't this be expensive?
-driveforce
Robert
Paul
Switzerland
Reply #8 - Jun 22nd, 2005, 1:07pm
Hello everybody,
trimming is indeed relatively expensive in production and that's what makes the cost of very precise voltage references. What is important when considering trimming is that you must be able to perform the compensation by measuring the voltage at a single temperature (ideally room temperature of course). If you need to measure the voltage at more than one temperature, you need to perform interpolation and the trimming algorithm becomes complex, thus even more expensive.
By the way, you should be aware that corner simulation does not take into account device mismatch, which will directly affect the stability of the bandgap voltage over temperature. The BJT matching is intrinsically good, but you should have a look at the influence of resistor and MOSFET matching on your Vbg(T) characteristic. Some people use mismatch compensation schemes, like chopping or auto-zeroing, to solve this problem, but it needs some area-expensive low-pass filtering.
Paul
ericjohnson
Reply #9 - Jun 22nd, 2005, 6:49pm
Yeah, trimming will certainly increase the cost. I'm just curious  how the IC manufacturers measure and perform trimming for a large volume production... Anyone could provide some details if you have experience?
