Aug 15th, 2024, 7:11am
Why no CAP and RES check report in LVS resul (Read 4003 times)
jayjay
Guest
Jun 30th, 2005, 2:14am
Dear all,
I am using the PDRACULA to do LVS, in the netlist there is description of CAP and RES such as:
Cp n1 n2 1p
xR2 n3 n4 rnwell l=100u w=3u
But there is no CAP and RES check report in the final LVS result. Would you please tell me why.
Thanks in advance
Jay
  IP Logged
jayjay
Guest
Re: Why no CAP and RES check report in LVS resul
Reply #1 - Jun 30th, 2005, 10:09pm
I guess that the LOGLVS complier can not regonize the RES and CAP in the input netlist, is it right?
  IP Logged
Reply #2 - Jul 4th, 2005, 2:25am
In your CDL netlist, you need to have (at the top, although not on the first line):
*.BIPOLAR
*.CAPVAL
*.RESVAL
The *.BIPOLAR is needed in order for LOGLVS to realise that it is not a MOS-only design (the use of the word bipolar is a little archaic) - essentially, the idea was that resistors and capacitors would be representing parasitics, perhaps, and so should be filtered out in normal usage for LVS.
jay_lin
big capacitor
Reply #3 - Jul 14th, 2005, 6:32am
Dear Andrew,
Thank you for your three-times' helps, I am so grateful.
Have a nice day!!
Jay
Jay
