You should set tstab to get you past between 1-5 time constants of the initial transient. 1-2 are usually enough, but more may be needed when convergence is tough. Tightening toleraces too tight can cause convergence problems. Start with default tolerances and only tighten them if you feel you need to. Keep an eye on the convergence norm. It is expected to start at some large number and drop to 1, which represents convergence. If there is no period of monotonic decrease, then you probably need to increase tstab. If it does go through a period of monotonic decrease and then seems to get stuck and never reach 1, then probably your tolerances are too tight.
If the balun is preventing you from getting convergence in DC, then you probably have not provided a DC current path for both the differential and common mode currents. Do not leave the C input open, tie it to ground either directly or through a resistor.
