One need not find AF or NOIMOD in the model file, since one can get noise from their default values (1.0 and 1, respectively). However, using the default NOIMOD=1, one must specify a value for KF to get flicker noise.
NOIMOD=2 or 3 uses the NOIA, NOIB, NOIC parameters, which have default values that generate flicker noise; however, they are probably not correct for your particular process (nor would the parameters from that link necessarily be correct, though the file name does seem to indicate that it's at least the right technology (0.35u)).
