May 11th, 2024, 10:47pm
vco's and all that jazz (Read 3130 times)
trond
Glasgow, Scotland
Jul 04th, 2005, 11:10pm
I have a basic question about VCO models and their actual circuit implementation. I know how to simulate and model a VCO mathematically but have difficulties translating this to a real circuit.
1)
For example, in a N-stage ring oscillator (simple differential pair with variable output time constant) where is the internal phase? Can I plot it in a real circuit as I can in a model? In the mathematical model it is just the integration of the frequency, i.e. idtmod(frequency, 0 ,1).
2) Speaking of the idtmod function, how does the real circuit reset itself when crossing a certain internal phase value and how can I change this?
Thanks.
trond
Glasgow, Scotland
Re: vco's and all that jazz
Reply #1 - Jul 5th, 2005, 11:41pm
Hmm...I might not have expressed myself in the right way. In VerilogA I can model a VCO using the idtmod function and then find out when the phase crosses multiples of PI/2 by using the @cross function. This is described in the VCO model from the Verilog-AMS page. My question is the following: How would I, in a circuit implementation of a VCO, have the internal phase reset at a certain value, and when it does, generate some sort of pulse? Most literature talks about ring oscillators and I am not quite sure where in such a circuit the internal phase is and how I can use it? Hopefully someone can help me understand this.
Reply #2 - Jul 6th, 2005, 12:41am
In general, circuit do not operate in the same way a behavioral model of a VCO based on an idtmod() function. The closest would be a relaxation oscillator. With the idtmod() function you always integrate up, whereas a relaxation oscillator integrates up half the time and down the other half.
