May 18th, 2024, 4:08am
PSS for SC-CMFB again (Read 3455 times)
ethan
Jul 05th, 2005, 1:17am
Hello Everybody,
For my fully differential fold-cascode OTA with SC-CMFB, according to the Ken's paper "Simulating Switched-Capacitor Filters with SpectreRF" and previous posts in 2003 and 2004, I use PSS and can achieve good common mode output voltage results when I let two input signals are disabled. I have used two "vsource" as my two differential inputs, and actually I set type=dc and leave others all blank.
But how can I get large signal transient plot from PSS, which just looks like the transient plot through conventional "tran" analysis. For example, from conventional "tran", normally if we set input with peak-to-peak 1mv sine wave, we can see large signal level in output sine wave, say peak-to-peak 2v~3v in some cases. But with PSS, right now, I only can get differential gain with 4 in rough from the PSS transient plot.
What I tried was to set vsource
type=sine,
and fill "frequency name 1",
"amplitude Vpk",
"phase for sinusoid 1",
and"sine dc level"=2.5v (which is common-mode input).
But It is expected to get 2000~3000 voltage gain.
So what I did wrong? Do I need to fill these specifications to get large signal transient plot in PSS?
Anybody can share his or her experience?
From then on, for PAC, after I set vsource "type=sine" with "display small signal params" and "PAC magnitude", "PAC phase", I got differential gain with 4 and about 10dB.
Any suggestion? Or my circuit indeed has only 10dB gain? I have replaced SC-CMFB with equavilent resistors, its gain goes up to 70dB.
Appreciate your help.
part of the netlist is attached:
// Cell name: fold_cascode_new_lowpower_sc_TG_PNOISE_invclk
// View name: schematic
//two input sources
V4 (Vin net082) vsource type=sine freq=30K ampl=500.0u sinephase=180 \
       sinedc=2.5 pacmag=500.0m pacphase=180 fundname="fin"
V1 (Vip net082) vsource dc=0 type=sine freq=30K ampl=500.0u sinedc=2.5 \
       pacmag=500.0m fundname="fin"
// two pairs of clock for SC_CMFB
V10 (ph2 0) vsource type=pulse val0=0 val1=5 period=5u delay=200.0n \
       rise=500p fall=500p width=2.2u fundname="clk2"
V36 (0 ph1_b) vsource type=pulse val0=5 val1=0 period=5u delay=0 rise=500p \
       fall=500p width=2.7u fundname="clk1_b"
V37 (0 ph2_b) vsource type=pulse val0=0 val1=5 period=5u delay=200.0n \
       rise=500p fall=500p width=2.2u fundname="clk2_b"
V8 (ph1 0) vsource type=pulse val0=5 val1=0 period=5u delay=0 rise=500p \
       fall=500p width=2.7u fundname="clk1"
//PSS and PACsimulation setup
   digits=5 cols=80 pivrel=1e-3 ckptclock=1800 \
   sensfile="../psf/sens.output"
pss  pss  fund=10K  harms=0  errpreset=moderate  tstab=1.5m
+    method=gear2only  maxacfreq=20M  annotate=status
pac  pac  start=1  stop=300M  maxsideband=0  annotate=status
Re: PSS for SC-CMFB again
Reply #1 - Jul 5th, 2005, 2:19pm
Why don't you leave the large signal inputs disabled and simply use PAC? It will be much faster.
ethan
Reply #2 - Jul 5th, 2005, 9:14pm
[quote author=Ken Kundert  link=1120551427/0#1 date=1120598371]Why don't you leave the large signal inputs disabled and simply use PAC? It will be much faster.
-Ken [/quote]
Thank you for your suggestion, Dr. Kundert,
The reason that why I set the large signal inputs is that I would like to see the large signal transient plot through PSS. If I disable the large signal inputs and use PAC mag only, I only can get common-mode output voltage level for PSS as before.
Can you comment why I couldn't get large signal transient plot for output voltage in PSS even though I set large transient signal inputs? Thanks a lot.
by the way, I still have a quesiton regarding PAC. I read a post in Mixed-signal Design forum that
http://www.designers-guide.org/Forum/?board=ms_design;action=display;num=1101544...
basically, he said " PAC is considering the whole signal (over a complete clock cycle) when computing the gain. If your signal spends half its time at zero due to a reset phase, that will effectivly reduce your gain by half (6 dB). "
Is that the reason why I only got 10 dB AC gain with PAC, instead of expected 60~70dB gain?
Thank you for your time and help.
ethan
Reply #3 - Jul 6th, 2005, 12:38am
Currently you are running a PSS analysis with both the clock and a "large" input signal present. This is not a transient per see, but rather a large signal steady-state analysis.
Applying the input tone during PSS is expensive, and should only be done if you are interested in large signal effects that are present as a result of the large input signal, effects such as distortion. If you are only interested in gain, you can save yourself a lot of time by applying the input signal as a small signal during a PAC.
Thus, typically, if you were interested in the gain of your clocked amplifier, you would apply the clock only and then perform a PAC analysis to compute the gain.
There is no reason why you should be confined to only a common-mode response with PAC.
The Fourier analysis in PSS does operate over the entire signal, and so if your signal has a 50% duty cycle, it will appear to have half the energy, or 6 dB less that a signal with 100% duty cycle. However, that cannot explain a difference of 60 dB.
