Uncle Ezra,
The frequency you are trying to resolve is: 2.451G-2.45G or 1MHz. So an FFT needs to have a fundamental frequency of 1MHz, or less. That is the frequencies of interest are 2.499G, 2.45G, 2.451G, and 2.452G. Given the length of the simulation is would be best to use 1MHz, or a simulation time of 1us. Next the circuit needs to reach sinusiodal steady-state, that is all the startup transients need to settle. Ac coupling, bias control loops, etc . may have long time constants. You will need to carefully control the time stepping, however, 1ps is probably too tight given the 1us simulation time. For the first cut, try setting the overall accuracy settings correctly and letting the time stepping algorithm control the time step.
BTW, have you filed a PCR and provided Cadence a testcase?
Art Schaldenbrand
