Jul 16th, 2024, 10:26am
Pages: 1 2 3 4
Class B RF Power Amplifier ,IIP3/OIP3 Spectre (Read 10312 times)
purplewolf
Jun 22nd, 2010, 3:40am
I am trying to simulate the OIP3/IIP3 of class B RF power amplifier using Cadence Spectre ..
I have tried the following analysis
1)QPSS with one large and one moderate tone
2)PSS with two large tones
3)PAC +PSS
I sweep the input power from -60dbm to 30 dbm whereas my amplifier inout referred one db (Pin 1dB) is at 20 dbm.
So, according to theory my IIP3 must be 20+9.6 or greater than that factor but I am getting IIP3 of 14 dBm ???
Secondly , does large signal means that Spectre analysis the circuit interms of harmonic balance techniques(strongly non-linear) while moderate or small signal means analysis interms of volterra series expansion (weakly non-linear)..
Do i need to provide different power levels if i choose one tone as large while other as moderate??
What exactly IIP3 OIP3 means in terms of class-B power amplifies? Does the theory in books regrding LNA,Mixer  IM products apply here?
I have tried every possible way to solve this issue and searched lots of forums and manuals but dont know how to fix it??
Re: Class B RF Power Amplifier ,IIP3/OIP3 Spectre
Reply #1 - Jun 22nd, 2010, 4:09am
Are your questions focusing on very specific vendor's simulator, Cadence Spectre ?
If so, post to simulator's board not design's board.
purplewolf wrote on Jun 22nd, 2010, 3:40am:
What scheme do you use for input and output in Class-B amplifier ?
Class-B Push-Pull using 180deg-Hybrid or transformer ?
If so, your result of IIP3 is relative reasonable, since 20+9.6-12=17.6dBm is close to 14dBm.
No. Both moderate and small signals are not volterra series expansion.
And small signal in PSS/PAC or QPSS/QPAC is pure linear analysis around periodical or quasi-periodical steady state operation points.
No.
But valid signal level for small signal in PSS/PAC and QPSS/QPAC is 10dB smaller than P1dBin(Input Refered 1dB Gain Compression Point) as Class-A amplifer.
You had better set level of moderate signal in QPSS smaller than P1dBin(Input Refered 1dB Gain Compression Point) as Class-A amplifer especially for Shooting-Newton QPSS.
See threads after following.
http://www.designers-guide.org/Forum/YaBB.pl?num=1262828862/18#18
« Last Edit: Jun 22nd, 2010, 8:48am by pancho_hideboo »
purplewolf
Reply #2 - Jun 22nd, 2010, 4:35am
Its a single ended design with input matching,stability , harmonic tank and output matching network.
Reply #3 - Jun 22nd, 2010, 4:39am
purplewolf wrote on Jun 22nd, 2010, 4:35am:
Its a single ended design with input matching, stability, harmonic tank and output matching network.
What is it ?
Use the followings. Don't use HB-SS or PSS/PAC.
(1) Two-tones HB based on one fundamental frequency in Agilent ADS
(2) Two-tones CR(=HB) based on one fundamental frequency in Agilent GoldenGate
(3) Two-tones HB-PSS in Cadence Spectre
(4) Two-tones HB based on two fundamental frequencies in Agilent ADS
(5) Two-tones CR(=HB) based on two fundamental frequencies in Agilent GoldenGate
(6) Two-tones HB-QPSS in Cadence Spectre
purplewolf
Reply #4 - Jun 22nd, 2010, 4:52am
A Parallel RC network in Series with the gate to ensure stability . The input matching is done after stability network.
Reply #5 - Jun 22nd, 2010, 4:54am
purplewolf wrote on Jun 22nd, 2010, 4:52am:
I got it.
See the followings.
http://www.designers-guide.org/Forum/YaBB.pl?num=1218635777/5#5
http://www.designers-guide.org/Forum/YaBB.pl?num=1272344339/3#3
3)PAC +PSS
Do you get same result as IIP3 in any of these three analyses.
When I have spare time, I will check P1dBin and IIP3 for Class-B amplifier using Agilent ADSsim although I also have Cadence Spectre.
See Class-B Power Amplifier in the following.
http://edocs.soco.agilent.com/display/ads2009/About+Amplifier+DesignGuide
Class B > Spectrum, Gain, TOI and 5thOI Points, and PAE vs. Power ; "HB2TonePAE_Pswp_ClassB.dds"
purplewolf
Reply #6 - Jun 22nd, 2010, 5:10am
but what does stability network has to do with IIP3 and OIP3??
the amplifier is already stable
purplewolf
Reply #7 - Jun 22nd, 2010, 5:10am
yes i get the same result for all three analysis...
Reply #8 - Jun 22nd, 2010, 5:14am
purplewolf wrote on Jun 22nd, 2010, 5:10am:
There is no relation generally
It is very strange.
I will check P1dBin and IIP3 for Class-B amplifier using Golden Standard RF Circuit Simulator Agilent ADSsim.
If you show me netlist of your Class-B amplifier, I can resimulate it using various simulators.
purplewolf
Reply #9 - Jun 22nd, 2010, 6:12am
i have generated the netlist but which file you would be needing to simulate it...and where to find the netlist file?
purplewolf
Reply #10 - Jun 22nd, 2010, 7:10am
here the netlist file...
change extension to .scs
purplewolf
Reply #11 - Jun 22nd, 2010, 11:01am
here are the files.
purplewolf
Reply #12 - Jun 22nd, 2010, 11:03am
thats the other
purplewolf
Reply #13 - Jun 22nd, 2010, 2:50pm
this is a device in umc 90nm...
i think its parameters dont appear in netlist..
how to get it??
RFICDUDE
Reply #14 - Jun 22nd, 2010, 4:03pm
Dude, you can't share proprietary foundry models and/or parameters.
Unless you have legal permission from the foundry to do so (usually requires a three way nondisclosure agreement).
Sometimes the EDA company has existing agreements with foundries, so in these cases you can share netlists with someone from the EDA company and they can simulate your netlist because they have or can obtain the foundry models.
Pages: 1 2 3 4
