Quote:Now comes the interesting part. First, I used pnoise analysis to find the edge-to-edge jitter (Jee) of a chain of inverters driven by a 100MHz clock.
Are you using Pnoise-jitter analysis ??
At what point of time are you strobing your noise ??
Are you trobing noise at transition time of you signal ??
Quote:I then ran a transient noise analysis with the following settings:
noisefmin=100kHz, noisefmax=50MHz, stop time=100us. The Jee I got from the waveform is 29.5fs. Does that mean transient noise analysis does not take into account of noise folding effect? I have repeated the experiment with different noise bandwidth and all yielded similar conclusion.
for including effects upto the level of 640x50MHz, are the accuracy settings correct ??
Is the simulator time-step << 1/(640x50MHz) so as to prop noise effects aof required harmonic content ?? Quote:Being a curious little kitty, I then repeated the experiment on VCO and I am even more confused. The oscillating frequency is at 800MHz and I have chosen the noise bandwidth from 100kHz to 10MHz to avoid integrating noise too closed to the carrier. From pnoise analysis, the cycle jitter (Jc) with different no. of cycles (k) is as follows:
k=1, Jc=415fs
k=8000, Jc=50ps
I assume that Jc values you are obtaining are from the cadence's Direct Plot Form for Spectre / ADE Calculator of Cadence Artist. Find out the formula used to calculate this value ??
Quote:On the other hand, transient noise analysis (with noisefmin=100kHz, noisefmax=10MHz, stop time=100us) gives the following:
k=1, Jc=583fs
k=8000, Jc=278ps
How are you obtaining this value of Jc ??
Are both values of Jc for tran noise as well as pnoise been obtained from Calculator using the same expression ??
Pls. quote the expression for Jc for k=1, as well as k=8000, if possible.
M
