May 4th, 2024, 1:07pm
A trivial question for Ken's paper SC-filters.pdf (Read 2327 times)
ethan
Jul 07th, 2005, 10:34pm
Hi everybody,
I have tried the examples in paper "Simulating Switched-Capacitor Filters with SpectreRF".
In the sc-filter netlist, the vin shows as following:
Vin  (in gnd) vsource type=dc pacmag=1.0
+ ampl=INPUT_AMPL freq=INPUT_FREQ fundname="input"
But I have tried all the ways in my "vsource" setup for my own circuit, I either could get the following specification for two differential vsources:
V4 (Vin net082) vsource type=dc pacmag=500.0m pacphase=180
V1 (Vip net082) vsource type=dc pacmag=500.0m
or I could get:
V4 (Vin net082) vsource type=sine freq=10K ampl=500m sinephase=180 \
       sinedc=2.5 pacmag=500.0m pacphase=180 fundname="input2"
V1 (Vip net082) vsource type=sine freq=10K ampl=500m sinedc=2.5 \
Then all of above netlists will work for PSS and PAC. Here is my question. I have run spectre in command line and open waveform with AWD(analog waveform display),
then in the sc-filter example, it displays:
        |TFin-pac
scf.raw-Run1-|clockAlone-td.pss
        |clockAlone-tran.pss
Then I found that through  "clockAlone-tran.pss", I can get figure 10 bottom plot in paper page 19. But with my own circuit setup, after running spectre, I only can get
pss-fd.pss
pss-td.pss
I couldn't get "pss-tran.pss" for my own circuit.
Did anybody, by any chance, try and somhow get pss-tran.pss in his or her own circuit?
ethan
Re: A trivial question for Ken's paper SC-filters.
Reply #1 - Jul 8th, 2005, 12:14am
Set saveinit=yes on the PSS analysis to get the pss-tran.pss file.
