May 19th, 2024, 11:06pm
question about large signal s-parameter (Read 3267 times)
danda821
Jul 12th, 2005, 1:21pm
I am wondering if there is a way to do large-signal s-parameter simulation in cadence. In ADS, you can do the simulaiton using LSSP. Thanks.
ssupin-ma
San Jose, CA
Re: question about large signal s-parameter
Reply #1 - Jul 12th, 2005, 2:32pm
PSP will do this for you.
(1) Set PSS with input port at the power level that you want
(2) Set PSP with input and output port that you want to check, set the harmonic at input and output at harmonic = 1 (or specified harmonic tone that you would check the S-parameter), set the single sweep frequency at the input frequency (relative 0Hz or Absolute fundamental freq.)
(3) sweep the PSS frequency can cover the frequency that you want to check.
Under some condition, you can keep the PSS frequency and sweep a (small) frequency range under PSP. and still get accuracte results. (but much faster)
Simon Roll Eyes
Ssu-Pin Ma (Simon)
Frank Wiedmann
Munich, Germany
Reply #2 - Jul 13th, 2005, 12:45am
I do not believe that this method will give the correct results if the circuit has significant nonlinearities, see http://www.designers-guide.org/Forum/?board=rfdesign;action=display;num=10822251....
Baolin Yang
Guest
Reply #3 - Jul 13th, 2005, 9:43am
ADS's LSSP does harmonic balance and the input port signal is set to one harmonic in simulation, even though the post-processing is similar to PSP.
The harmonic balance simulation has nonlinear effects. So the result is different from PSP. Only if the power level of the input port signal is very low, the result will be very close to that of PSP.
  IP Logged
