May 16th, 2024, 10:08pm
how to use wreal? (Read 3709 times)
Monia
Guest
how to use wreal?
Jul 14th, 2005, 4:20am
I want to drive a wreal net using a real variable.
Doing the folloeing:
module test ()
wreal out;
real out_test;
assign out = out_test;
analog begin
out_test = 19.0;
I get an error during compilation related to the
"assign" statement":
transition sensitivity on analog value/expression is not supported.
Why?
M
  IP Logged
Re: how to use wreal?
Reply #1 - Jul 14th, 2005, 7:36am
A wreal is an event-driven signal type and so cannot be made dependent on a continuous time variable. Doing so could make the value of the wreal vary continuously, which its event-driven nature could not reasonable represent.
You must assign to out the value from an event driven variable.
