pletch
Berkeley, CA
Berkeley, CA
I'm simulating phase noise for a pretty standard LC VCO and I get the following warning from the pnoise analysis:
********************************************************************** Periodic Noise Analysis `pnoise': freq = 3.03189 GHz + (1 kHz -> 1 MHz) *********************************************************************** Using the operating-point information generated by PSS analysis `pss'.
Warning from spectre at freq = 1 kHz during PNoise analysis `pnoise'. Relative residual of linear system is significantly above tolerance. Results may be inaccurate.
pnoise: freq = 1 kHz (0 %), step = 0 Hz (0 %)
The pss analysis seems to complete fine and the results seem reasonable. I have tried tightening simulator tolerances, increasing maxacfreq, and the standard pnoise solver and oscsolver modes (instead of turbo). I still get the warnings at almost every frequency step out to about 1MHz.
I'm not sure if I can trust these results or not because of the warning. Can anyone recommend a course of action to correct the warning? The message seems to suggest I need to increase tolerances, but I don't want inaccurate simulation results.
Thanks, nate
