May 19th, 2024, 12:50am
Write to file (Read 13389 times)
noreng
Write to file
Jul 18th, 2005, 11:42pm
How do I write simulation results to a file?
Eugene
Re: Write to file
Reply #1 - Jul 19th, 2005, 8:52am
Since you posted this question under VerilogAMS I assume you want to know how to write data to a file within a VerilogAMS module. I do this all the time with VerilgoA, which should work in AMS. Suppose you want to sample and record V(out) and V(in) every deltaT seconds. Try
parameter real deltaT=1u;//for example.
real integer fptr;
analog begin
 @(initial_step) begin
    fprt = $fopen("file path");
 @(timer(1p,deltaT) begin
    $fstrobe(fptr,"%g %g",V(in),V(out));
 @(final_step) fclose(fptr);
noreng
Re: Write to file
Reply #2 - Jul 20th, 2005, 1:41am
I've followed your advice, but it doesn't work.
The following code
       @(timer(1p,deltaT)) begin
         $fstrobe(fptr,"%g %g",reff1, reff2);
leads to the following error message:
'src/cswb_4_file.vla', line 108: Error : Illegal identifier specified. Identifiers starting with '$' must identify system tasks or functions.
'src/cswb_4_file.vla', line 108: Error : 'fstrobe' must be a variable.
'src/cswb_4_file.vla', line 108: Error : Syntax error
'src/cswb_4_file.vla', line 108: Error : Syntax error near '('.
Thanks in advance.
Re: Write to file
Reply #3 - Jul 20th, 2005, 3:52am
I think from a previous posting, you are using Eldo. The $fstrobe certainly works in spectre.
I took a look at the LRM http://www.designers-guide.org/VerilogAMS/VlogAMS-2.2-pub.pdf (well, that's the abridged version), but that doesn't mention $fstrobe. Rather bizarrely it discusses $fopen/$fclose, but it's not obvious what you'd do with the results of these functions...
Haven't got time to look further right now.
Re: Write to file
Reply #4 - Jul 20th, 2005, 4:30am
The $f-functions are defined in the IEEE 1364 Verilog Language Reference Manual, from which the Verilog-AMS LRM is derived.
Apparently, the AMS $fopen/$fclose system tasks are slightly different, and hence are defined for AMS in the AMS LRM, but the tasks to do anything with the opened file are identical to the 1364 definitions, and thus are omitted.  I think that makes it hard to use the AMS LRM, but fixing that wasn't in the project scope when I updated the LRM to 2.2.
1364-1995 Verilog has $fstrobe $fdisplay $fwrite as well as a few special versions of these for binary data.  I'm surprised that any simulator would not have these, since they've been in the language for years.  (The 1995 version had only limited provision for *reading* from a file.)
BTW, the full 2.2 AMS LRM is available from
http://www.eda.org/verilog-ams/htmlpages/public-docs/lrm/2.2/AMS-LRM-2-2.pdf
-Geoffrey
noreng
Re: Write to file
Reply #5 - Jul 20th, 2005, 4:32am
If there are any Eldo users who are reading this.
If the $fstrobe is replaced by $fwrite, it is possible to write to file.
The rest of the code can be used as is.
Re: Write to file
Reply #6 - Jul 20th, 2005, 10:42pm
Thanks Geoffrey - I was sure this was part of the language (should have remembered that it's standard Verilog), but didn't have time yesterday to look it up properly.
Jess Chen
California Bay Area
Re: Write to file
Reply #7 - Jul 21st, 2005, 8:39am
Does Eldo support VerilogAMS or just VerilogA?
-Jess
noreng
Re: Write to file
Reply #8 - Jul 21st, 2005, 11:32pm
Eldo supports both.
If you are including a Verilog-AMS file in an eldo testbench, you have to use
vasim testbench
instead of
eldo testbench
Jess Chen
California Bay Area
Re: Write to file
Reply #9 - Jul 22nd, 2005, 12:07am
Interesting. Thanks for the information.
-Jess
jbdavid
Re: Write to file
Reply #10 - Oct 17th, 2005, 1:25am
Just to clarify based on MY observations with one vendors tool - the way you open, close and write to files is a little different if you do it in the analog or digital domains..  - Pay close attention to IEEE-1364 when working in an "always" or "initial" block, and
closer attention to the Verilog-AMS LRM when working in an analog block.. or when writing Verilog-A models .. At least for now.
Jonathan
[quote author=Geoffrey_Coram  link=1121755337/0#4 date=1121859017]The $f-functions are defined in the IEEE 1364 Verilog Language Reference Manual, from which the Verilog-AMS LRM is derived.
Apparently, the AMS $fopen/$fclose system tasks are slightly different, and hence are defined for AMS in the AMS LRM, but the tasks to do anything with the opened file are identical to the 1364 definitions, and thus are omitted. -Geoffrey [/quote]
jbdavid
