Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Aug 17
th
, 2024, 5:17am
Home
Help
Search
Login
Register
PM to admin
Design
RF Design
› Linearity
Previous topic
Next topic
Linearity (Read 2399 times)
uncle_ezra
Linearity
Jul 21
st
, 2005, 2:15am
As voltage scales down, is linearity worsened for LNA and mixer? Given same circuit one @ 1.8V for 0.15um and another @ 1.5V for 0.13um. Also in LNA, how does the inductor source degeneration affect the linearity?
IP Logged
nano_RF
madison
Re: Linearity
Reply #1 -
Jul 27
th
, 2005, 10:54pm
As a general notion as you decrease the voltage linearity should degrade. But when constant filed scaling is considered and it can be thought that (vgs- vt) is constant for both technology then linearity should not be much affected.
There are many ways to explain linearity in conjuction with source degeneration. like feedback and gm-linearity. I will try to explain in a simpler way, may be that will do.
If u have a source degenerated common source configuration then source node approximately follows that gate voltage that mean u'll have approximately Vgs acroos the degenration resistor or inductton. this will create a current Vgs/R(impedanc eof source resistor). So now ur drain current is pretty linear in conjuction with Vgs. Now it is just Vgs/R whereas previously it was foloowing a square law characteristic. Further u can also prove that now Gm of the amplifier has become a constant (1/R).. previously it was a fucntion of vgs.
So i think this will explain the linearity issue.
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
»» RF Design
- Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
- Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
