If you're using recent versions (I don't remember whether it was IC5033 or IC5141 when this came in; IC5141 I think), then the parasitic backannotation and reporting in the "MSPS" tool has changed so that you need to do a DC simulation in order to see the resistor values. Previously it used to just add up all the resistors and display that, which was quite frankly wrong.
You say your simulation results are absurd - unfortunately I can't help you with that without more details.
I suggest you read the documentation on the MSPS stuff carefully. I think (can't check right now) it's at:
<instdir>/doc/parasim/paramsim.pdf
