Aug 16th, 2024, 12:21pm
Input power extrapolation point (Read 3599 times)
ssk_288
Miles to Go
Bangalore
Jul 28th, 2005, 2:40am
Hi all
I am a new user to Cadence. I am simulating a downconversion mixer in SpectreRF. I am using PAC analysis with PSS.
To plot the IP3 it asks to specify "input power extrapolation point" .
1) What does that mean?
2) As I change its value the IP3 also changes?
Thanking you in advance
regards
SUDHIR S. KUDVA
Re: Input power extrapolation point
Reply #1 - Jul 28th, 2005, 5:32am
Sudhir,
1) The IP3 is figure of merit extrapolated from the
     "linear" region of operation. Since the IP3 exists
     outside the "linear" region, it is calculated by
     extrapolation.
     By "linear" we are refering the region where the
     output power increases linearly as the input power
     increases.
     You might  want to make sure that you are at least
     >10dB below the 1dB compression to make improve
     quality of the extrapolation.
2) As long as the circuit is behaving linearly, the IP3
   point should the same. When the output starts to
   compress, the extrapolation is no longer valid.
    The other factor to be aware of is that the
    accuracy of the third harmonic calculation is the
    lower limit of the extrapolation accuracy.
    You should check that the slope of the third-order
    intermodulation product 60dB/decade. If the slope
    is less than accuracy of the simulation should be
    improved.
     BTW, there should be an app-note on simulating
     mixers on Sourcelink that should explain IP3 with
     pictures. Also the SpectreRF theory manual may
     provide useful information.
