Sudhir,
1) The IP3 is figure of merit extrapolated from the "linear" region of operation. Since the IP3 exists outside the "linear" region, it is calculated by extrapolation.
By "linear" we are refering the region where the output power increases linearly as the input power increases.
You might want to make sure that you are at least >10dB below the 1dB compression to make improve quality of the extrapolation.
2) As long as the circuit is behaving linearly, the IP3 point should the same. When the output starts to compress, the extrapolation is no longer valid. The other factor to be aware of is that the accuracy of the third harmonic calculation is the lower limit of the extrapolation accuracy. You should check that the slope of the third-order intermodulation product 60dB/decade. If the slope is less than accuracy of the simulation should be improved.
BTW, there should be an app-note on simulating mixers on Sourcelink that should explain IP3 with pictures. Also the SpectreRF theory manual may provide useful information.
