May 4th, 2024, 3:14pm
FBH-HBT Model (Read 1444 times)
mahboul
FBH-HBT Model
Jul 28th, 2005, 11:44am
Hi All,
Is someone outside there who used this model (FBH HBT by Matthias Rudolph from www.designers-guide.org ) with spectre.
It's running with ADS but in spectre it's not converging.
Mahboul
Re: FBH-HBT Model
Reply #1 - Jul 28th, 2005, 11:53am
Matthias just sent me a new version (2.1). You might try downloading the latest version and trying again.
mahboul
Re: FBH-HBT Model
Reply #2 - Jul 28th, 2005, 12:25pm
Hi Kent,
I tried with FBH-HBT(vers.21) I got the same results.
If I use the model with the default values I got an error:
in line 412 divede by zero and
in the parameter definition in line 144 the range of Fb has to be changed to [0.0:inf).
If I use realistic parameter values it is still not converging (with the same parameters in ADS I have the expected results )
Mahboul
Matthias Rudolph
Guest
Re: FBH-HBT Model
Reply #3 - Jul 28th, 2005, 11:30pm
Hi Mahboul,
the code was developed and tested with ADS only, but it should converge with every simulator!
We dont have Spectre here, so I can not offer to test your simulation, but if you send me the model parameters, maybe I see something.
Best regards,
Matthias
  IP Logged
Re: FBH-HBT Model
Reply #4 - Jul 29th, 2005, 8:00am
It might also be worth checking your version of Spectre.  Are you using one of the newer releases that compiles the Verilog-A? (IC5141 or MMSIM6)
mahboul
Re: FBH-HBT Model
Reply #5 - Jul 29th, 2005, 9:49am
Hi
I'm using version 4.4.6.
OK I will try a newer version (If it's available) and let you know.
mahboul
Re: FBH-HBT Model
Reply #6 - Aug 1st, 2005, 3:55am
Hi Geoffrey,
now the model is working. I used version 5.0.33 of spectre, Thanks!!
Hi Matthias,
I have now excactly the same results with spectre and ADS, Thanks
Mahboul
Re: FBH-HBT Model
Reply #7 - Apr 4th, 2006, 8:15am
I just sent an e-mail to Matthias asking about some problems with the model.
Most of them center around the self-heating model implementation, which I believe is broken, or at least does not match the "usual" implementation of self-heating, whether in built-in models or Verilog-A code for Mextram 504, HiCUM, VBIC, etc.
I hope there will be an updated version soon.
