Without seeing the whole set of equations, it looks like you're on the right track. Typically, the base current has an ideal term Ib(ideal) = Is * (exp(vbe/vt) -1) and a non-ideal term Ib(nonideal) = Isn * (exp(vbe/(2*vt) -1)
where Isn is bigger than Is, so that it dominates at low vbe, but at high vbe, the factor ne1 (usually ~2) means that the exponential is smaller. With more base current, the gain ic/ib is smaller.
