Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Aug 18
th
, 2024, 4:21pm
Home
Help
Search
Login
Register
PM to admin
Modeling
Semiconductor Devices
› Pspice Modeling of BJT curve Ib vs Vbe
Previous topic
Next topic
Pspice Modeling of BJT curve Ib vs Vbe (Read 2868 times)
vjoshi
Aug 05
th
, 2005, 12:56pm
Now I have setup my circuit as follows. There is a current source at the base with step curent of 200mA and then a resistor of 1 G ohm is connected . So how do i measure for getting Ib vs Vbe curve . I am getting a linear curve having a slope of 1 when i run the probe for Ib vs V: Q1(b) (ie ) voltage across Base and emitter.
Since the Base emitter junction is acting like a diode it should give me a flat curve for voltage less than threshold voltage and then at the voltage when the diode turns on it should give a vertical straight line high current at that threshold voltage.
So can u advice where i am doing wrong or can u refer to someone who could help me out.
IP Logged
Re: Pspice Modeling of BJT curve Ib vs Vbe
Reply #1 -
Aug 18
th
, 2005, 9:59am
A step current of 200mA? Could be that's too large, and the junction current is linearized to avoid blowing up the exponential.
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
- RF Design
- Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
»» Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
- Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
