Apr 28th, 2024, 9:27am
GNDs for Analog & Digital (Read 604 times)
Vishwanath M
Guest
Aug 08th, 2005, 4:36am
I have digital & Analog blocks sitting on the same die.  Problem is to connect ground (Gnd) for digital & Analog.
Could u please tell the Advantages & Disadvantages of having the Configurations in terms of noise, etc..
1. Connect seperate DGnd & AGnd.
2. AGnd for Digital & Analog
3. DGnd for Digital & Analog.
4. take Seperate Gnd for Digital & Analog then go for shorting in the board level (PCB).
Thanks in advance.
Vishwanath M
  IP Logged
Paul
Switzerland
Re: GNDs for Analog & Digital
Reply #1 - Aug 8th, 2005, 9:39am
Vishwanath,
in order to discuss this topic, it is important to know whether your design is integrated on a high- or low-resistivity substrate. Simply check whether you are using an epi process or not.
Maybe you could also mention the operating frequencies of digital and analog part, as well as the sensitivity of analog (high-resolution converter and RF vs. low-resolution blocks).
In the meantime, you can already have a look at the following document:
http://www.specctra.de/whitepapers/sca443.pdf
Paul
