This is really a case of RTFM.
You need to have set up the .cdsplotinit file - see the plotting configuration guide:
<instdir>/doc/plot/plot.pdf
(also easily located in "cdsdoc").
Then use Design->Plot->Submit (I think that's the menu, from memory).
It's not that hard to set up!
