In LRM 2.2, you're supposed to be able to get it by $simparam("gmin")
However, I don't believe any simulator supports this yet, so you probably have to set up a parameter in your module parameter real gmin = 1e-12 from (0:1); and then pass the value into the module from the instance line in the netlist. Presumably, you can access the simulator's gmin from the netlist.
