Sep 17th, 2026, 5:41am
complex signal processing (Read 2734 times)
trond
Glasgow, Scotland
Aug 26th, 2005, 12:42am
Hello All,
I was wondering whether if it is possible to do complex signal processing in VerilogA/MS. The manual does not say anything about it. I tried using “zi_np” and defining complex poles and zeros, but VerilogA/MS told me that I need to have complex conjugate zeros and poles.  Furthermore, can I define complex voltages such as V=a+j*b in VerilogA/MS?
If so, can someone please comment on this?
Any feedback is appreciated.
Re: complex signal processing
Reply #1 - Aug 26th, 2005, 3:35am
svensl -
You can't define complex voltages such as V=a+j*b in VerilogA/MS.  There was some talk about adding complex support as an extension to better support RF, but this effort fizzled out.
zi_np's third argument, according to the LRM, is a vector of N pairs of real numbers, where the first number if the real part and the second the imaginary part.  If you put a non-zero imaginary part, then you have to put in the complex conjugate yourself (same real part, -imaginary part).  (One might argue that the simulator should add this in for you ... )
I've had some difficulties with simulators not really agreeing on what a "vector" is in some cases -- I was trying to use noise_table, and I wasn't able to use an array
 int noisevals[10];
I had to use a comma-separated list of numbers enclosed in braces {}, and the numbers had to be constants (fixed numbers, or I think I was able to use parameters).
