Jul 16th, 2024, 7:32am
gmin (Read 2333 times)
king
gmin
Aug 26th, 2005, 5:29am
Hi everyone,
In SPICE, GMIN can be accessed through ckt->gmin.
How do you access GMIN (or its equivalent)
in VerilogA in ADS?
Re: gmin
Reply #1 - Aug 26th, 2005, 5:33am
In LRM 2.2, you're supposed to be able to get it by
$simparam("gmin")
However, I don't believe any simulator supports this yet, so you probably have to set up a parameter in your module
 parameter real gmin = 1e-12 from (0:1);
and then pass the value into the module from the instance line in the netlist.  Presumably, you can access the simulator's gmin from the netlist.
