Aug 15th, 2024, 2:16pm
Cadence IC5.033 hangs on Fedora Linux (Read 1576 times)
Carl Chao
Guest
Aug 30th, 2005, 9:47pm
I'm using Cadence IC5.033 on Fedora Core2 linux. It all runs and simulates ok. Only when after I have done some simulations in Analog Evironment mode, if I try to close the Analog Evironment window, the computer system just freezes (no error messages, and I could not even enter linux interactive mode (?) by pressing ctrl+alt+F2)), and each time when this happens I have to hard reboot the computer. I believe this is probably due to some linux library compatibility issue. Does any one know what is and how to solve this problem?
Thanks!
CC
  IP Logged
